New VCSc and VCSe install public call routing help needed
I am working on my first VCS deployment.  I have followed the deployment guides and am having issues with calls coming in from the public internet.  I want to route publid internet calls in to an extension on a CUCM server.
The call fails and when looking at the Search History, it appears the calls is being classified in the Default zone and not the Traversal zone.
Can anyone provide any suggestions or additional configuration on what may be missing?
Here is the output from the Call Search:
    Search (9)
        State: Completed
        Found: True
        Type: H323 (LRQ)
        CallRouted: True
        CallSerial Number: 220f53aa-a6c1-4988-af79-e59eebf8c804
        Tag: 2f6b8680-7e14-11e3-8c11-0010f31be958
        Source (1)
            Authenticated: False
            Aliases (1)
                Alias (1)
                    Type: H323Id
                    Origin: Endpoint
                    Value: 2036831768@webex.com
            Zone (1)
                Type: Default
            Path (1)
                Hop (1)
                    Address: 199.19.190.116
                Hop (2)
                    Address: 199.19.190.87:5061
        Destination (1)
            Alias (1)
                Type: H323Id
                Origin: Unknown
                Value: 5800@74.218.141.85
        StartTime: 2014-01-15 13:38:11
        Duration: 0
        SubSearch (1)
            Type: Transforms
            Action: Not Transformed
            ResultAlias (1)
                Type: H323Id
                Origin: Unknown
            SubSearch (1)
                Type: Admin Policy
                Action: Proxy
                ResultAlias (1)
                    Type: H323Id
                    Origin: Unknown
                SubSearch (1)
                    Type: FindMe
                    Action: Proxy
                    ResultAlias (1)
                        Type: H323Id
                        Origin: Unknown
                    SubSearch (1)
                        Type: Search Rules
                        CallsToUnknownIPAddresses (2)
                            Mode: Direct
                            Zone (1)
                                Type: Default
                                Protocol: H323
                                Found: True
                                Duration: 0
                                Gatekeeper (1)
                                    Address: 74.218.141.85:1720
                                    Alias (1)
                                        Type: H323Id
                                        Origin: Unknown
Here is the output from my Search Rules:
48          Local zone - no domain          Any           Any           No           Alias pattern match           Regex           (.+)@cpgint.com.*           Replace           Continue           LocalZone           Enabled          View/Edit
50          Local zone - full URI          Any           Any           No           Alias pattern match           Regex           (.+)@cpgint.com.*           Leave           Continue           LocalZone           Enabled          View/Edit
100          Traversal zone search rule          Any           Any           No           Any alias                                         Continue           Traversal zone          Enabled          View/Edit
150          DNS zone serach rule          Any           All zones           No           Alias pattern match           Regex           (?!.*@%localdomains%.*$).*           Leave           Continue           DNS zone          Enabled          View/Edit
Thanks in advance
Jesse
  • Collaboration
Everyone's tags (2)
Re: New VCSc and VCSe install public call routing help needed
I make use of the following transform and search rule
Voice CCIE #37771
Thank you for the screenshots.  I was able to apply your method and have success with inbound calling.
Do you also place outbound calls using the VCS?  I can from endpoints registered to the VCSc, but any calls from CUCM fail.  I have created search rules to use the DNS zone, but the calls still fail.  Do you ahve a similar configuration for outbound calling?
Also, do you use the same domain on CUCM as you do on the VCS?
HI,
Yes I make use of a transform rule to take any say e164 number with a domain behind it and send it to the cucm which has transformation patterns or translation patterns on it to push the call via the pstn.
See attached.
Voice CCIE #37771
I was able to place outgoing calls from my endpoint to other video enabled endpoints, but I am having issues with the calling id presentation on the other side.  Here is my setup:
EX90 --  CUCM -- VCSc -- VCSe -- Remote Video Endpoint
I needed to create a CPL script on the VCSc to rewrite the calling alias of the call.  However, there doesn't seem to be the right elements in the CPL script to change the calling id .  When I make an outbound call, the calling id displays:
"jesse  jesse@lightspeedtech.net"
and I am using this in my CPL file to translate my extension@:
jesse@lightspeedtech.net">
I would prefer the calling id on the remote side to display my full name and the alias.  does anyone have any insight how I can make this work?
Jesse
596
