09-23-2013 09:53 AM - edited 03-15-2019 05:27 AM
Hi All,
We're running CUCM 9.X. I want to integrate Cisco 9971, 8945 with TP Endpoint (EX60 and Tandberg C40). I read this wonderful document (https://supportforums.cisco.com/docs/DOC-30750) but still I have some doubt.
What is the difference bewteen MCU, VCS and ISR (DSP 3). For what I know, ISR running DSP3 is the chepaiest option but I'm not sure if HD Video is supported.
Thansk in regards
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
Solved! Go to Solution.
09-23-2013 10:43 PM
Hi There
as per the document you are referring to which I posted prevously
VCS is a call control system like call manager but for video end points only, while CUCM is for both voice and video and now it is becoming very mature call control system for video communications with native support for many video end points registations
MCU is a hardware that can be used to host multi point/party video calls that can be registered to CUCM or VCS depending on the design
ISR with DSP/PVDM 3 is the same concept of the MCU but can be used for small multi-point calls and normally for remote sites that need local hosting to a call to reduce the load on the WAN link when most of the participant from the same location for example ! and it dose support HD but limited capabilities compared to MCU
for example PVDM3 doe not support HD when participants are expected to use different video formats
hope this help
09-25-2013 12:39 AM
to my knowledge there is no support currently for direct VCS-E to CUCM and in this case you need VCS-C
hope this help
if helpful rate
09-23-2013 10:43 PM
Hi There
hope this help
09-24-2013 11:39 AM
Thanks for the answer (+5).
I have one more question. Can I integrate a VCS Express with CUCM 9.X + MCU (without VCS Control)?
09-25-2013 12:39 AM
hope this help
if helpful rate
09-25-2013 05:42 AM
Thanks my friend for your help .
