10-29-2014 07:03 AM
Has anyone noticed that the "Answer Questions" page isn't updating, or is it just me? It doesn't matter which device I sign in from, the newest question is listed as:
Configuring Secure LDAP in CUCM 8.6 Hi,I have 2 clusters of CUCM version 8.6 deployed and one of them has configured with Secure LDAP while the other is not. I do know the steps to co... in Other Collaboration, Voice, and Video Subjects by tacl75@hotmail.com 23 min 30 sec ago
Yet, when I go to this question, it is six days old with no responses. If I go to the individual communities, I get more up-to-date content, but not at the main "Answer Questions" page.
I thought it might be related to my interests, but when I select the "Modify My Interests" link, I am told that I don't have access to this page.
Any thoughts?
Jody
Solved! Go to Solution.
10-29-2014 09:16 AM
Hi Jody,
Thanks for reporting this issue. We have narrowed down this problem to be some caching issue for users having Cisco partner access level. For issue with accessing modify my interests, you can go to My account by clicking the down arrow next to your avatar on corner right to view your interests. We will have development investigate and get back to you as we have more information.
Thank you,
Amy Chang
10-29-2014 09:16 AM
Hi Jody,
Thank you,
Amy Chang
10-30-2014 05:48 PM
Thanks, Amy! Looks like the latest update fixed it all up.
10-30-2014 05:50 PM
Hi Jody,
Thank you! We actually had a code deploy earlier today which cleared the cache. Not sure if it fully fixed the problem but we'll be monitoring it for the next few days to see if it requires changes to fix it further.
Amy Chang
11-01-2014 08:10 AM
Looks like the fix only worked temporarily. The behaviour has returned.
Jody
11-01-2014 10:16 AM
Hi Jody,
Ok, I have informed development and will get back with an update early next week regarding timeframes.
Thank you,
Amy Chang
11-06-2014 05:34 PM
Hi Jody,
We have rolled out a temp fix for this issue by removing the caching on this page. I believe this should fix the issue but we will check again tomorrow as this problem normally happens over time.
Amy Chang
11-06-2014 05:37 PM
Thanks, Amy. Your assistance is appreciated.
11-05-2014 11:11 AM
Hi Jody,
We are working on a hot fix for this issue and targeting the release to happen sometime tomorrow evening. Will update this discussion once I have more information.
Amy
