CWMS hostnames are not treated as valid subject alternate names for a public certificate
I have a problem to get s public certificate for my CWMS Server 2.0
fqdn for public vip is "meet.company.de"
But the fqdn hostnames for admin and media vm are "admin.company.corp"
The public certification authority does not accept our CSR because the Subject Alternate Name xxxx.company.corp ist not valid
Any ideas how we can proceed? Wildcard certificate is not an option.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello, There are couple of
There are couple of things you can try to do:
1. Change the Certification Authority. At least until November 2015, CAs should accept internal company domains and provide SSL certs for them. Not sure what CA you are trying to use, but I've seen Verisign, GoDaddy, Entrust, etc. providing SSL certs for internal domain names (using SAN certs)
2. Change the FQDNs of your internal VMs. You would need to ensure you configure "company.de" zone in your internal DNS, create DNS entries for all the internal VMs, Private VIP and Admin and WebEx Site for "company.de" domain, and then perform the hostname change on CWMS for all the VMs and Admin site. You can change the VMs hostnames if you go to CWMS Dashboard > System > View More, and by clicking on each VM you will get an option to change the hostname. If the hostname is defined in DNS and resolves to the same IP address as the original hostname, the entry will be properly updated. (NOTE: don't change the IP addresses if not really needed. If needed, take a look at the instructions here) . Once you modified all the hostnames, you can generate new CSR (SAN) and you will get valid internal VM hostnames and your CA will be able to issue you a certificate.
3. If you end up using the same domain name on all the VMs and VIPs, you may consider wildcard certs (not sure why the are not the option in your case).
This is all that you can do when it comes to this issue.
I hope any of this will help.
-Dejan
1 REPLY
-Dejan
173
