Community Member
HLB for CWMS (WebEx) IRP set up
Hi , We are having CWMS on prrm setup in our infra..includes,Admin..Media & IRP with HA system for all... In coming days... our organization is going to introduce a component (F5) for VPN solution for end user, which also contains the Hardware Load Balancing (HLB) feature.... Just wanted to check below things... 1) Is it possible to introduce HLB in existing Cisco cwms setup? 2) How we can achieve this ?...we have split-horizon network topology for Cisco setup. 3)Is the CWMS setup with the HLB deployed with any Cisco customers..? Please help me with the setup guidelines or any shared links so I can proceed with feasibility of this. Regards, Sagar
Everyone's tags (1)
No external load balancing
No external load balancing solution is supported with CWMS.  The system handles its own load balancing.  You'll find that info in the Planning and Design guides for CWMS.
Hailey
Community Member
Thanks Much David
Thanks Much David
187
