Is CUCM mandantory for CWMS
I have a client who wish to use CWMS purely for desktop sharing and control.  No audio conference is require. The client is not using CUCM for the telephony system, and they dont want CWMS to call in and dial out for audio.
Is CUCM a mandatory requirement for CWMS ?
Will Cisco support a standalone CWMS without CUCM integration ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi, If you are not going to
If you are not going to use Teleconferencing feature of the product, and don't plan to import users from CUCM/LDAP and authenticate using CUCM/AXL, I don't see why you would need CUCM.
You just won't configure Audio section of the solution to use WebEx Audio, and instead the system will only support "Voice connection using computer" option. You won't be able to disable both types of audio conferencing feature. You must have at least one enabled, and in your case, it would most likely be "Voice connection using computer"option.
I hope this helps.
-Dejan
I hope this helps.
-Dejan
Thanks Dejan,I have
Thanks Dejan,
I have confirmation from Cisco pre-sale. CUCM is not mandatory for standalone CWMS.
148
