MeetingPlace 6.1 - question about calls dropping
                   We had an issue on 8/28/2013 at approximately 1:15pm EST where the phone lines within the same facility where our MeetingPlace audio system resides- had gone dead.  Please rearch to determine if any or all the participants that were curently on MeetingPlace (adio) were also dropped at that time.  I am attaching ralted files.  Thanks, Ray Capriolo - raymond.capriolo@realogy.com - 973.407.5050
1 ACCEPTED SOLUTION
Hi Ray,
After analyzing the logs, it seems that the ongoing MeetingPlace audio calls were also affected during the phone outage. The issue seems to affect the MeetingPlace meetings at 13:18:48.
The following major alarms were indicated during the outage of T1 Lines at 13:18:48 :
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0x9)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 0, [-1], span 9)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=9
08/28 13:18:48 MAJ  0xb014f  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0)
                    Lost Signal detected on this T1/PRI span ([14], card 0, [-1], span 0)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=0
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0xc)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 0, [-1], span 12)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=12
08/28 13:18:48 MAJ  0xb014f  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0x1)
                    Lost Signal detected on this T1/PRI span ([14], card 0, [-1], span 1)
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0xd)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 0, [-1], span 13)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=13
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0x4)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 0, [-1], span 4)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=4
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0x5)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 0, [-1], span 5)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=5
08/28 13:18:48 MAJ  0xb014f  0/3, "HWFAULT", 0 (0xe, 0, 0xffffffff, 0x6)
                    Lost Signal detected on this T1/PRI span ([14], card 0, [-1], span 6)
                    T1 NETWORK: ADDR=0,SLOT=-1,PORT=6
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0x1, 0xffffffff, 0)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 1, [-1], span 0)
                    T1 NETWORK: ADDR=1,SLOT=-1,PORT=0
08/28 13:18:48 MAJ  0xb0151  0/3, "HWFAULT", 0 (0xe, 0x1, 0xffffffff, 0x1)
                    Incoming Alarm Indication on this T1/PRI span ([14], card 1, [-1], span 1)
                    T1 NETWORK: ADDR=1,SLOT=-1,PORT=1
The following meetings indicate that the users were disconnected from the meetings:
Meeting Id = 6645
Line 1762: 08/28 13:09:22.55  C ae464    ADD Part Part  6 User GUEST SP+ Port 149
Line 1763: 08/28 13:10:50.07  C ae464    ADD Part Part  7 User GUEST SP+ Device Web
Line 1814: 08/28 13:18:48.12  C ae464    Blast OD : User Id    3, Dest                 // Result: User Leaving Conf
Line 1828: 08/28 13:18:48.13  C ae464    Blast OD : User Id    3, Dest
Line 1846: 08/28 13:18:50.88  C ae464    Blast OD : User Id    3, Dest
Line 1893: 08/28 13:18:53.29  C ae464    Blast OD : User Id    3, Dest
Line 1895: 08/28 13:18:53.29  C ae464    Ending   : Main Conference
Line 1964: 08/28 13:20:44.63  C ae464    Starting : Main Conference
Line 1966: 08/28 13:20:44.63  C ae464    ADD Part Part  8 User GUEST SP+ Port  59
Meeting Id = 9077
Line 1756: 08/28 13:05:02.21  C ae815    ADD Part Part  7 User GUEST SP+ Port 139
Line 1796: 08/28 13:18:48.11  C ae815    Blast OD : User Id    3, Dest             // Result: User Leaving Conf
Line 1820: 08/28 13:18:48.12  C ae815    Blast OD : User Id    3, Dest
Line 1822: 08/28 13:18:48.12  C ae815    Blast OD : User Id    3, Dest
Line 1871: 08/28 13:18:52.07  C ae815    Blast OD : User Id    3, Dest
Line 1873: 08/28 13:18:52.07  C ae815    Blast OD : User Id    3, Dest
Line 1886: 08/28 13:18:52.97  C ae815    Blast OD : User Id    3, Dest
Line 1890: 08/28 13:18:52.98  C ae815    Blast OD : User Id    3, Dest
Line 1892: 08/28 13:18:53.10  C ae815    Ending   : Main Conference
Line 1952: 08/28 13:20:36.19  C ae815    Starting : Main Conference
Line 1954: 08/28 13:20:36.19  C ae815    ADD Part Part  8 User GUEST SP+ Port  50
Line 1958: 08/28 13:20:41.12  C ae815    ADD Part Part  9 User GUEST SP+ Port  65
Meeting Id = 3803
Line 1757: 08/28 13:05:28.87  C ae79c    ADD Part Part  5 User GUEST SP+ Port 141
Line 1800: 08/28 13:18:48.12  C ae79c    Blast OD : User Id    3, Dest          // Result: User Leaving Conf
Line 1816: 08/28 13:18:48.12  C ae79c    Blast OD : User Id    3, Dest
Line 1824: 08/28 13:18:48.12  C ae79c    Blast OD : User Id    3, Dest
Line 1866: 08/28 13:18:51.63  C ae79c    Blast OD : User Id    3, Dest
Line 1868: 08/28 13:18:51.86  C ae79c    Ending   : Main Conference
Line 1938: 08/28 13:20:28.97  C ae79c    Starting : Main Conference
Line 1940: 08/28 13:20:28.97  C ae79c    ADD Part Part  6 User GUEST SP+ Port  58
Line 1962: 08/28 13:20:42.26  C ae79c    ADD Part Part  7 User GUEST SP+ Port  74
Rishabh
1 REPLY
Hi Ray,
Meeting Id = 6645
Meeting Id = 9077
Meeting Id = 3803
Rishabh
514
