Meetingplace 6 - Need JAVA Version help
I am running Meetingplace 6,  it is currently running Java 6 Update 45,  This version of JAVA  is susceptible to vulnerabilities.
Has anyone tested Java 7 to see if Meetingplace 6 still works with the latest Java Version installed?
Thanks.
Mitch
Hi Mitch,
The only component for MeetingPlace 6.x that depends on Java is MeetingPlace Directory Services (MPDS), which is the Active Directory/LDAP integration for automatic user profile creation. Unless you're using MPDS it should work fine. If you do have MPDS, this was never tested with Java 7 and we would have no idea if it would continue working with it. The web conferencing is based on Flash Player so that should not be affected.
Andrew
Cisco TAC
we are using MPDS.  Java 6 update 60 should work fine, but I cannot find a download link to it.  Any ideas?
Hi Mitch,
It doesn't look like that is available publically since End of Public Updates for Java 6 was Feb 2013 according to this notice:
http://www.oracle.com/technetwork/java/javase/eol-135779.html#Java6-end-public-updates
It looks like the latest one is Update 45:
http://www.oracle.com/technetwork/java/javase/downloads/java-archive-downloads-javase6-419409.html
Andrew
Cisco TAC
Yes, I know it is not public, I figured Cisco would have access to such things.
358
