Abandoned Call Calculation From Termination Call Detail
HI..
Can someone please tell me how to calculate  Abandoned Calls  from Termination Call Detail Table ?.
Thanks in advance.
Hi,it depends on what you
it depends on what you mean by "Abandoned calls". Is it the number of calls abandoned while waiting in the queue + the number of calls abandoned while ringing at the agent phone?
If so, TCD might not be the best option. What I would do is to insert CallTypes into the ICM script and then check the Call_Type_Interval view (or Call_Type_Half_Hour, depends on if your setup supports 15 minutes long intervals or not) and take the number of RouterCallsAbandQ (and perhaps RouterCallsAbandToAgent) for that particular CallType.
G.
Hello Gergely,Thanks for your
Hello Gergely,
Thanks for your reply.
Actually, I wanted to calculate Abandoned calls network wise (network name based on ANI) in both cases as below.
"abandoned while waiting in the queue + the number of calls abandoned while ringing at the agent phone"
From which TCD leg, I can get this?
Hi, it depends. What is your
Hi, it depends. What is your ICM and IP IVR (or CVP) version?
G.
Hi Gergely,In our case its 8
Hi Gergely,
In our case its 8.5.
Thanks.
Hi,alright, it
alright, it's
CallDisposition 6 for the VRU PG's and CallDisposition 3 for the CUCM PG.
For instance:
SELECT COUNT(*) FROM Termination_Call_Detail tcd WHERE tcd.DateTime > CAST(FLOOR(CAST(GETDATE() AS FLOAT)) AS DATETIME) AND tcd.PeripheralID = 5000 AND tcd.CallDisposition = 3
SELECT COUNT(*) FROM Termination_Call_Detail tcd WHERE tcd.DateTime > CAST(FLOOR(CAST(GETDATE() AS FLOAT)) AS DATETIME) AND tcd.PeripheralID IN (5001,5002) AND tcd.CallDisposition = 6
G.
Hi, Gergely.Could you advise,
Hi, Gergely.
Could you advise, how to get the list of calls that were abandoned while being held at an agent position from TCD? I need to figure exact ANIs for such calls. Tried to search for calls with CallDisposition 6, but there are no such calls at all. However, I know that there are some from the WebView Agent22 report (Aban Hold counter) and from Agent_Skill_Group_Half_Hour.AbandonHoldCallsToHalf field.
Hi,that's kind of strange.
that's kind of strange. Can you get me a list of Peripherals and CallDispositions for that particular day?
You probably want to run SELECT tcd.PeripheralID, tcd.CallDisposition, COUNT(*) AS cnt FROM Termination_Call_Detail tcd WHERE tcd.DateTime > @desiredDateFrom AND tcd.DateTime < @desiredDateTo GROUP BY tcd.PeripheralID, tcd.CallDisposition ORDER BY 1,2
Thanks.
G.
Thanks for reply, Gergely.One
One thing I forgot to mention, I need that information in regards of one agent.
So here is the output for the procedure, there are some CallDispositions of 6.
PeripheralID CallDisposition cnt
5000         1               76
5000         3               192
5000         4               79
5000         6               9
5000         7               53778
5000         10              474
5000         13              1086
5000         14              14570
5000         15              4946
5000         19              25
5000         26              9
5000         27              5
5000         28              2053
5000         29              50
5000         30              16841
5001         6               7601
5001         13              2731
5001         28              7592
5002         6               15849
5002         13              4879
5002         28              15192
5003         3               1
5003         4               5
5003         6               2
5003         7               3996
5003         10              1645
5003         13              1
5003         14              1930
5003         26              150
5003         27              9
(30 row(s) affected)
But when I use the same select and specify the AgentPeripheralNumber I get only this:
5000         4               2
5000         7               36
5000         13              1
5000         14              237
5000         28              14
5000         29              1
5000         30              247
(7 row(s) affected)
However, I know from Webview report and Agent_Skill_Group_Half_Hour.AbandonHoldCallsToHalf table that this agent had 4 aban hold calls for the specified day.
Hi,let's try the other way
let's try the other way around, filtering out rows with CallDisposition 6 and then take a look at all call legs. I have a feeling that the agent was in the middle of transferring the call when the customer disconnected. This could actually mean that it's not even going to be CallDisposition 6
Can you try the following SQL queries, export the result to CSV, post the result to here:
DECLARE @dateFrom DATETIME, @dateTo DATETIME
SET @dateFrom = '2014-07-22 00:00:00' /* use your datetime here */
SET @dateTo =   '2014-07-23 00:00:00'
SELECT tcd.RouterCallKeyDay, tcd.RouterCallKey,tcdx.*
LEFT OUTER JOIN (SELECT * FROM Termination_Call_Detail WHERE DateTime > @dateFrom AND DateTime < @dateTo) tcdx
ON tcd.RouterCallKeyDay = tcdx.RouterCallKeyDay AND tcd.RouterCallKey = tcdx.RouterCallKey
WHERE tcd.DateTime > @dateFrom AND tcd.DateTime < @dateTo
AND tcd.CallDisposition = 6 AND tcd.RouterCallKeyDay > 0
ORDER BY 1,2
Then the following one too (this filters out rows for the agent):
AND tcd.AgentSkillTargetID = 6349 /* your agent's skilltargetid */
ORDER BY 1,2
Thanks.
G.
Could be the transferred calls. I have run the queries and attached files with the output.
Hi, can you please tell me
Hi, can you please tell me the SkillTargetID of the agent plus the approximate time (from the Agent_Skill_Group_Half_Hour table). Thanks.
G.
Sure, SkillTargetID of that
Sure, SkillTargetID of that agent is 12017. Below is the part of the Agent_Skill_Group_Half_Hour table for the specified agent and day, where I found the abandoned hold calls.
DateTimeSkillTargetIDSkillGroupSkillTargetIDRecoveryKeyAbandonHoldCallsToHalf
05.07.201412:00:001201751066442054992252
05.07.201414:00:001201751066442055003561
05.07.201414:30:001201751066442055005901
Thanks!
Hi,I don' understand this
I don' understand this.
This way: I don't have a 8.5 UCCE handy, only a 8.0 one (with IP IVR) and a 10.0 one (with IP IVR as well). I decided to replicate this issue on the 8.0 UCCE.
First try: incoming ACD call, agent picks it up, places the call on hold, caller disconnects. TCD CallDisposition 6 on Peripheral 5000, with the correct AgentSkillTargetID filled in. Agent_Skill_Group_Interval table AbandondHoldCalls incremented.
Second try: incoming ACD call, agent picks it up, initiates a consult transfer, call is placed on (network) hold, caller disconnects. Same result (CD 6, periph 5000, AbandonHoldCalls incremented).
Third try: incoming ACD call, agent picks it up, initiates a single step transfer to a CTI route point with a simple script behind it, the caller is placed into a queue which in turn places the call on hold (IP IVR script Call Hold step). Caller disconnects. Now this is getting interesting, the row with the AgentSkillTargetID is marked with CD 28 (blind transfer) and if I read on the rows with the same RCKD and RCK, the call is marked with CD 6 but on the VRU Peripheral. AbandonHoldCalls is not incremented.
I am out of ideas.
Is the Agent State Trace enabled for this particular agent? Can you take that for me, too?
Is there any other call scenario your agent(s) use? For instance, do they initiate conferences?
G.
Hi, Gergely.Thank you for
Hi, Gergely.
Thank you for your help, I realy appreciate this.
I agree this is a stange behavior, by the way, we have 7.5(1) version.
Luckly we have Agent State Trace enabled. I attached the csv file with the events for this particular agent for the entire day.
Regarding the call scenarios, I will make a research. I am new to that system, it was configured before me. But I think it is quite possible, that conference might be a case.
Hi, Gergely.I think, I found
Hi, Gergely.
I think, I found those abandoned calls. Here we have a Voice Record system. So each call from the client is in fact in conference with the agent and Voice Record system.
I analyzed the Agent State Trace, particulary EventName and AgentState columns.
And I found, that for a normal call the flow is :
DateTimeEventNameCode
2014-07-05 12:02:59.0006WORK_READY
2014-07-05 12:03:00.0003READY
2014-07-05 12:03:01.0008RESERVED
2014-07-05 12:03:02.0004TALKING
2014-07-05 12:03:02.00310CALL_HELD
2014-07-05 12:03:02.0109CALL_INITIATED
2014-07-05 12:03:02.0134TALKING
2014-07-05 12:03:02.02013CALL_CONFERENCED
2014-07-05 12:03:49.0006WORK_READY
And here is the call flow for the abandoned call, this is where CALL_HELD goes straight to WORK_READY. So I assume it is lost from hold.
2014-07-05 12:00:40.0006WORK_READY
2014-07-05 12:00:41.0003READY
2014-07-05 12:00:42.0008RESERVED
2014-07-05 12:00:43.0004TALKING
2014-07-05 12:00:43.00310CALL_HELD
2014-07-05 12:00:43.0109CALL_INITIATED
2014-07-05 12:00:43.0134TALKING
2014-07-05 12:00:43.02013CALL_CONFERENCED
2014-07-05 12:02:58.00010CALL_HELD
The only thing I have not figured yet, how to track ANI for such calls.
Hi,just a quick question
just a quick question about your ANI question: is there a RouterCallKeyDay and RouterCallKey column in the report you are looking at? RCKD and RCK is supposed to be the unique call id for the whole duration of the call (with some exceptions).
G.
Got it. Exactly what I was
Got it. Exactly what I was looking for. Now I can track them down in the TCD table by RCK. Thanks a lot Gergely, apreciate your help.
Dennis, this is great news
Dennis, this is great news indeed.
One more thing: did you/would you spend some time with the agent to gain more information about these calls? I would like to see what happened there, from the point of view of the agent.
Thanks for the rating.
G.
Gergely, unfortunately I did
Gergely, unfortunately I did not have a chance to talk to that agent. Will try to get in touch and gain more details.
Thanks.
Hi Gergely,
Hi Gergely,
Could you let me know how to take logs of calls hitting cvp error DN ?
1551
