Active PIM / PGAGENT on PG side B swich over to PG side A whenever the side A server is rebooted
Hi Team,
I have a weird behaviour on a newly installed Peripheral Gateway VRU in duplex mode duplex version 8.0.
Whenever the PIM and the PGAGENT is active on side B (side A is Idle) and I restart the side A Server, the MDS process on side B is terminated when the side A finish booting.This behaviour is only found when the side A server is rebooted.
Please note that on both side there is no preferred side configured on PG side A and B.
Underneath is the PGAGENT's trace from side B perspective. I have also enclosed the MDS and OPC trace... Has anybody found this kind of behaviour or got any idea of what is going on ?
Thank you !
Nick
Events from April 10, 2014:
14:00:43:312 PG3B-pgag Trace: TOS requested but no TOS connection exists.  Assuming unreachable.
14:00:43:312 PG3B-pgag DMP Agent process activated.
14:00:43:328 PG3B-pgag Connection to Central Controller side B failed (high priority).
  Last EMT Error [64]: The specified network name is no longer available.
14:00:43:328 PG3B-pgag Connection to Central Controller side A failed (medium priority).
14:00:43:328 PG3B-pgag Connection to Central Controller side B failed (low priority).
14:00:43:328 PG3B-pgag Connection to Central Controller side A failed (low priority).
  Last EMT Error [10053]: An established connection was aborted by the software in your host machine.
14:00:43:328 PG3B-pgag Connection to Central Controller side B failed (medium priority).
14:00:43:328 PG3B-pgag Connection to Central Controller side A failed (high priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side B established (medium priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side B established (high priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side B established (low priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side A established (medium priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side A established (high priority).
14:00:53:593 PG3B-pgag Connection to Central Controller side A established (low priority).
14:00:53:609 PG3B-pgag Path to Central Controller side B established.
14:00:53:625 PG3B-pgag Path to Central Controller side A established.
14:00:53:625 PG3B-pgag Central Controller side B is in service.
14:00:53:625 PG3B-pgag Central Controller side B reports good response time.
14:00:53:625 PG3B-pgag Initializing message stream with side B of the Central Controller.
14:00:53:625 PG3B-pgag Central Controller side A is in service.
14:00:53:625 PG3B-pgag Central Controller side A reports good response time.
14:00:53:718 PG3B-pgag Path to Central Controller side A is now idle.
14:00:53:718 PG3B-pgag Path to Central Controller side B is now active.
14:04:39:718 PG3B-pgag Connection to MDS process has failed.
  Last EMT Error [-519897069]: The remote process has exited.
14:04:39:718 PG3B-pgag MDS is out of service.
14:04:39:718 PG3B-pgag DMP Agent process being deactivated.
14:04:39:718 PG3B-pgag Path to Central Controller side A disconnected.
14:04:39:718 PG3B-pgag Path to Central Controller side B disconnected.
14:04:39:718 PG3B-pgag Message stream to Central Controller has been broken.
14:04:49:984 PG3B-pgag Connection to Central Controller side A established (high priority).
14:04:49:984 PG3B-pgag Connection to Central Controller side A established (medium priority).
14:04:49:984 PG3B-pgag Connection to Central Controller side A established (low priority).
14:04:49:984 PG3B-pgag Connection to Central Controller side B established (medium priority).
14:04:49:984 PG3B-pgag Connection to Central Controller side B established (low priority).
14:04:49:984 PG3B-pgag Connection to Central Controller side B established (high priority).
14:04:55:718 PG3B-pgag Connection to MDS process established.
14:04:55:718 PG3B-pgag Reconnection to MDS process completed successfully.
14:04:56:359 PG3B-pgag MDS is in service.
Everyone's tags (1)
Silver
14:00:43:312 PG3B-mds Trace:
14:00:43:312 PG3B-mds Trace: Synchronizer breaking dedicated path.
14:00:43:312 PG3B-mds Connectivity with duplexed partner has been lost due to a failure of
the private network, or duplexed partner is out of service. Last EMT Error [64]: The specified
14:00:43:312 PG3B-mds Trace: Synch high priority transmit thread exiting.
14:00:43:312 PG3B-mds Trace: Synch low priority transmit thread exiting.
14:00:43:312 PG3B-mds Trace: Synch changing to testing state.
14:00:43:312 PG3B-mds Trace: Synch medium priority transmit thread exiting.
14:00:43:312 PG3B-mds Trace: 0 - messages kept in local ordering queue.
14:00:43:312 PG3B-mds Trace: 2 - messages cleared from peer ordering queue.
14:00:43:312 PG3B-mds Trace: 0 - messages cleared from timed delivery queue.
14:00:43:312 PG3B-mds Initiating test of peer Synchronizer.
14:00:43:312 PG3B-mds Trace: Sending TOS request: sequence = 1.
14:00:43:312 PG3B-mds Trace: Received TOS response: sequence=1 status=UNREACHABLE.
14:00:43:312 PG3B-mds Trace: Sending TOS request: sequence = 2.
14:00:43:312 PG3B-mds Trace: Received TOS response: sequence=2 status=UNREACHABLE.
14:00:43:312 PG3B-mds Peer Synchronizer was found to be unreachable.
14:00:43:312 PG3B-mds Trace: Synch changing to isolated-enabled state.
14:00:43:312 PG3B-mds Synchronizer switching to non-duplex operation.
14:02:40:109 PG3B-mds Trace: Ignoring 'SetSystemTimeAdjustment', Time Synchronization is Disabled
14:02:40:109 PG3B-mds Trace: Synchronizer is releasing clock master mutex.
14:02:50:109 PG3B-mds Trace: Ignoring 'SetSystemTimeAdjustment', Time Synchronization is Disabled
14:02:50:109 PG3B-mds Trace: Synchronizer has obtained the clock master mutex.
14:02:55:093 PG3B-mds Trace: Node Manager ping received.
14:02:55:109 PG3B-mds Trace: Ignoring clock master status event in state Isolated-Enabled
If I'm understanding your post correctly, everything seems normal and working as designed. What you're seeing is the peer-to-peer redundancy that the message delivery system (MDS) offers; MDS works on the private network. What you have is side B of the PGAG process active, so the test other side (TOS) gets initiated over the public network when side A reboots and goes from duplex to non-duplex mode. Additionally, you'll see that you go from In-Service Paired to Isolated, and again, this is by design. Once side A comes back up, the enabled role should go back to side A IF MDS side B was the enabled side.
Hi Omar,Thank you for your
Hi Omar,
Thank you for your answer !
In my lab, I tried to duplicate this behaviour, and whenever the PG server Side A is restarted, and the PIM and the PGagent become active on Side B, the PIM andthe  PGagent never switch back to Side A once the reboot is over.
This is what bother me, and I couldn't find any official statement from Cisco saying that Side A is always the preferred side...
Now looking back to the PGagent trace, the MDS process side B dies whenever the PG Side A is back to normal :
I don't know if this is a normal behaviour...
Nick
Silver
Documentation attached
1022
