Community Member
Agent State for Incoming Calls (Non-IPCCx)
We have run into a small issue that I have received some questions on and I haven't been able to find an answer. Here is the situation as described by one of our supervisors.
We've had an occurrence that we like to get a better understanding of:
• Client logged into Agent software
• Client in ready mode
• Inbound call to extension xxxx - not an ipcc call
• Agent software switches to not ready mode
• Inbound call terminated
• Agent software switches back to ready mode.
That's the typical scenario, but there seems to be a specific time limit where that Agent software will not return to ready mode after the termination of inbound call to extension.
I haven't been able to find any timer related to this. From what I can see about half of their calls that come in are either DID or someone dials an extension directly from a main prompt.
We are running CCM4.2.3sr3 and IPCCx 4.0.4sr1.
Any ideas?
Eric
1 REPLY
Silver
Re: Agent State for Incoming Calls (Non-IPCCx)
I've tested it, but on IPCC 4.0.5 and during non-ipcc call agent is not ready (you can differentiate non-ipp call and manual not ready using reason codes), after this call agent goes back ready. it doesn't matter how non-ipcc long call is.
regards,
PK
140
