04-12-2006 01:07 AM - edited 03-13-2019 11:40 PM
Hi.
I have a script which uses Voice Browser and Get Digit String steps. The problem is that the Get Digit String step throws an exception while the Voice Browser step runs successfully.
;nested exception is:
com.cisco.dialogservices.RecognitionException:MRCP Recognition Completion Cause:9, Name:uri-failure, Description: Failure accessing a URI.
I have set as Primary Dialog Group the MRCP ASR Group and the Cisco Media Group as Secondary. If I change the order of Dialog Groups(Primary=Cisco Media, Secondary=MRCP ASR), then the Get Digit String step runs but not Voice Browser and the message I get is:
Voice Browser exit with error; netsted exception is:
com.cisco.voicebrowser.VBExecutionException:Fatal Error; nested exception is:
com.cisco.dialogservices.UnsupportedGrammarException: Grammar type not supported.
Is there any parameter I have to configure? I use CallManager 4.1(3), CRS 4.0(1)SR01_Build055, Scansoft OSR 3.0.4 and SWMS 3.1.9 (MRCP Server).
Thank you.
04-18-2006 08:24 AM
12-15-2006 05:23 AM
Are solved your problem, because i have exctly the same problem!!
if you solved your problem, can you please send me an email at ymechenene@activeo.fr
Thanks you for your feedback.
Best regards,
Youssef.
07-02-2007 10:20 PM
Did you solve the problem about: Get Digit String doesnt work on MRCP. I have exactly the same one. Please inform me.
10-10-2007 08:11 AM
Did anyone find a solution to this problem finally? I have the same problem, the first time it happend i did a recovery of the IVR, but then it happend again after a week and i did another recovery, but this time it didnt work out with the recovery.
I have a TAC case opened with Cisco, but it seems like it would be hard to get some kind of help from them.
10-10-2007 08:20 AM
hi jefa,
yes i have solve my problem.
It's a bug software and the TAC send to me an ES pack.
Good luck.
Youssef.
10-10-2007 08:38 AM
Hi Youssef,
Have you had any kind of problems after installing the ES pack?
Im gonna write to my TAC engineer right now and tell him what you told me.
10-10-2007 08:50 AM
After the ES pack installed, the problem is solved.
What is exactly your problem and software version?
