Blocking incoming calls in IPCCX!!!!
How can i block certain calls, callers, IDs
in IPCCX, after I collect caller IDs?
Vlada
1 ACCEPTED SOLUTION
Silver
Re: Blocking incoming calls in IPCCX!!!!
Assuming you have the Calling Line ID in a variable use something like:
If strCallingLineID == "1234" Then
-> True
-----> Terminate (Triggering Contact)
Please rate useful posts!
Silver
-> True
Can i have some kind of database with unwanted numbers and according to those DB to terminate
can U explain to a little bit, and does that step goes after ACCEPT step
Thank You
Vlada
Silver
Yes, the CLI check goes after the Accept step (you to Accept the call before you can process it through a script). I did look at the Reject step, but its behaviour is different: the call follows the Call Forward No Answer setting of the CTI port the call was forwarded to.
You could have a database of unwanted numbers and perform a lookup, then terminate the call if a number is found. You need IPCC Express Premium to perform database dips.
Thanx man
I'll try
Vlada
119
