Build a IPCC lab to learn
have a friend who likes to build a small lab to learn on IPCC express etc all HW and SW.
I would appreciate any help in finding the BOM and approximate cost, how to get it etc.
New or used - what ever gets him the tools to learn CM, IPCC etc.
Thanks in advance.
Baseer.
Community Member
Re: Build a IPCC lab to learn
Hi Baseer,
If you have the softwares (CCM and IPCC), you can install everything on VMWares. That is the best solution for a lab I think.
With best regards,
Chawki
I would appreciate some document or some thing that can tell me how to etc or what I need.
I think there is an old Cisco document from the 5.0 days which explains how to build a lab. Google for it and if you don't find it I can check my backups to see if I have it somewhere.
david
Community Member
Hi Baseer,
Here is a link for the CM 6 version install under VM:
http://www.blindhog.net/how-to-install-call-manager-6x-in-vmware/
For IPCCX, it is pretty straight forward. You only have to modify your VM HW config such as allocating more RAM and so on. Just go through it and raise your questions if needed. I will try to help you.
With best regards,
Chawki
Community Member
hi Chawki
Do you have the exact vmware requirements for ipcc 5? I keep getting hw is not supported
Community Member
Yes I had the VM installed with this:
-Memory 2048
-hard disk: maximum size to 80Go
-2 virtual processors
Tell me if you need more info.
With best regards,
Chawki
Community Member
Hi Chawki,
Where can i get the IPCCx 5.O image / evalaution version to install on VMware image for lab/ study
Ranjan
Community Member
Hi Ranjan,
UCCX 5.0 can not be downloaded and must be ordered at Cisco. If you want to use it for demo purposes, you can buy it for around 100 euros if you are a Cisco partner and if I am not mistaking.
There is no evaluation version though.
Chawki
230
