Call Noise excessive - 2801
i've a problem with outgoing and incoming calls, the call results to be disturbed, with noise.
I can call outside and inside, but the quality of the calls are very bad.
Anybody have an idea about this problem?
Following the configuration of the router 2801:
version 12.3
service password-encryption
hostname VG-01
boot-start-marker
boot system flash:c2801-spservicesk9-mz.123-14.T6.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
network-clock-participate wic 3
network-clock-select 1 BRI0/3/0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name XXXXXXXXXXX.XX
no ftp-server write-enable
isdn switch-type basic-net3
voice-card 0
voice class codec 1
codec preference 1 g711ulaw
username XXXXXX privilege 15 secret xxxxx
translation-rule 1
Rule 0 XXXXXXXXXX 1
interface FastEthernet0/0
description *** Link to 2950 ***
ip address 172.16.15.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/3/0
no ip address
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn sending-complete
isdn static-tei 0
interface BRI0/3/1
no ip address
shutdown
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
logging trap debugging
logging facility local1
logging 172.16.15.200
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
input gain -3
output attenuation 3
echo-cancel coverage 32
no vad
no comfort-noise
cptone IT
voice-port 0/3/1
ccm-manager mgcp
mgcp
mgcp call-agent XXX.XXX.XXX.XXX service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp validate domain-name
mgcp profile default
dial-peer voice 100 pots
preference 1
service mgcp
destination-pattern 0.
port 0/3/0
dial-peer voice 555 voip
preference 1
service mgcp
destination-pattern XXXXXXXXXX
translate-outgoing called 1
session target ipv4:XX.XX.XX.XX
incoming called-number .
dial-peer voice 101 pots
preference 1
service mgcp
destination-pattern 3T
port 0/3/0
1 REPLY
Re: Call Noise excessive - 2801
Thanks a lot everybody, but i solved the problem....
here in europe the ISDN standard is A-LAW for voice port, so i've inserted this command on the voice-port:
compand-type a-law
This command will solve any noise problem on european isdn.
Bye.
180
