Bronze
Calling SQL experts to help write a query
Trying to find some help from some sql experts.
I was asked to help write a query showing each Dialed_Number, the associated Call_Type, and Script(s) in an ICM configuration.
All the data I’m looking for seems to be in the following tables:
Dialed_Number (DialedNumberString, EnterpriseName, DialedNumberID)
Call_Type (CallTypeID, EnterpriseName)
Dialed_Number_Map (DialedNumberID, CallTypeID)
Call_Type_Map (CallTypeID, MasterScriptID)
Master_Script (MasterScriptID, EnterpriseName)
Thus far, my query looks like this:
SELECT     distinct Dialed_Number.DialedNumberString, Dialed_Number.EnterpriseName AS DN_Name, Call_Type.EnterpriseName AS Call_Type_Name,
                      Master_Script.EnterpriseName AS ScriptName
FROM         Call_Type_Map CROSS JOIN
                      Call_Type CROSS JOIN
                      Dialed_Number CROSS JOIN
                      Dialed_Number_Map CROSS JOIN
                      Master_Script
However, it’s returning every possible combination (it was 10x worse before adding the word ‘distinct’)
Ideally, I’d like the results to just show one row for each Dialed_Number (assumes 1:1 ratio of DN to CallType).
e.g.:
DN_Name           DialedNumberString      CallType_Name                ScriptName
Can anyone offer any guidance or suggestion?
Everyone's tags (3)
Green
I often do that at the end of the deployment to get a spreadsheet showing exactly that - DN, call type, scheduled script.
select DialedNumberString AS DN,  d.Description AS DN_Description, c.EnterpriseName AS CallType,
ms.EnterpriseName as ScriptName
from t_Dialed_Number_Map m, t_Call_Type c, t_Dialed_Number d, Call_Type_Map ctm, t_Master_Script ms
where ctm.Item = 0
and m.CallTypeID = c.CallTypeID
and c.CallTypeID = ctm.CallTypeID
and m.DialedNumberID = d.DialedNumberID
and ms.MasterScriptID = ctm.MasterScriptID
and d.RoutingClientID = 5000
order by DN
Geoff
Bronze
Re: Calling SQL experts to help write a query
Thanks Geoff,
I'd put this out on a couple different channels, and while yours is pretty good (I did remove the RoutingClientID from the where clause), I got another version that works just as well, and also includes DNs without CallTypes, and those which may have a CallType, but no script.
SELECT dn.DialedNumberString, dn.EnterpriseName AS Dialed_Number_Name, ct.EnterpriseName AS Call_Type_Name, ms.EnterpriseName AS Script_Name
FROM Dialed_Number dn
LEFT OUTER JOIN Dialed_Number_Map dnm ON dn.DialedNumberID = dnm.DialedNumberID
LEFT OUTER JOIN Call_Type ct ON dnm.CallTypeID = ct.CallTypeID
LEFT OUTER JOIN Call_Type_Map ctm ON ct.CallTypeID = ctm.CallTypeID
LEFT OUTER JOIN Master_Script ms ON ctm.MasterScriptID = ms.MasterScriptID
I believe the "joins" are supposedly more efficient, too.
Thanks for your contribution!
Green
Steve.
DNs without call types - never have them. What's the point?
DN call types always have a scheduled script - otherwise, what's the point.
Agree that explicit JOINS are more efficient, although it's just the config. Can't really be an issue.
I do move the routing client ID around - CUCM, CVP, EIM etc. Sorry about that bit.
Geoff
Bronze
I suppose the benefit *to me* is that it shows ALL the Dialed_Numbers.
For example in my lab, your query only returned ten rows.  The second query returned fifteen, and may help in situations where there's a misconfiguration.
Green
Steve,
I think I get it. You are looking for a misconfig where you have forgotten to associate the DN with a CT? Of course, I never make mistakes like that.
Geoff
Votes for you guys as this thing is awesome!
david
Bronze
Thanks David,
I used the query above as a template to write a similar one, listing every Agent, what peripheral they're on, what Agent_Team they're a member of, and whether or not they're a Supervisor.
Enjoy.
Select a.EnterpriseName AS AgentName, at.EnterpriseName AS Agent_Team_Name, a.SupervisorAgent, p.PeripheralName AS CCSiteName
from Agent a
left outer join Agent_Team_Member atm on a.SkillTargetID = atm.SkillTargetID
left outer join Agent_Team at on atm.AgentTeamID = at.AgentTeamID
left outer join Peripheral p on at.PeripheralID = p.PeripheralID
HI All,
I am trying to run above queries; but i am not getting any results :-(
I am putting above queries in a new query editor windows on AW and run it; but no results.
Please help me how do i run above queries.  These queries look exceptionally useful.
Thanks & Regards,
Piyush
Hi Guys,
I got it. 5 star for all.
1695
