06-21-2014 02:26 PM - edited 03-14-2019 01:33 PM
Hello Guys,
Can you help out here.
ntp on first node is ok and in sync
dns and reverse dns for both nodes are ok
both VM as exactly the same and UCCX same version
First node is already integrated with CUCM cluster with basic configuration and basic application tests running alright. Agents are able to log and calls are redirected to them.
license for HA is ok
second node added by IP and as well as by name (tried both ways) on first node and restard first node.
Security password ok
Tried to add second node but Configuration validation on installed procedure reports first node is not a first node.
What should i do ?
06-23-2014 08:13 AM
Try rebooting node one. Then try to add the HA Node.
06-23-2014 08:25 PM
Hi ,
Check default Gateway and VLAN taging on 2nd VM .
Ravi
06-25-2014 09:33 AM
I managed to sort the issue. Security password was created using a @ (Special Character) Linux does not like that.
08-25-2014 07:07 AM
I have the same issue. How did you get around the @ character?
thanks
02-05-2015 08:23 AM
The issue is the security password that is user to calculate the box license MAC. You cannot use special characters. Solutio was to install both box from 0 without @
Thanks. Sorry for the late response.
10-13-2014 05:35 PM
Not sure if it's a matter or Linux not liking the "@" character. It's OK using the "@" character for the platform and application user passwords. It's more sensitive on the Security Password.
8.5 Installation Guide says to use alphanumeric, hyphen, and underscore for the Security Password.
