CCX 8.5 ODBC Connection PASSED but JDBC Connection keeps failing with SQL 2005
Hi All,
I have searched this partucular thread in supportforums butnot found the workaround.
In my setup, I have SQL 2005 Standard Edition (SP3), UCCX 8.5.
I have installed JDBC Driver 1.2.5 and it is successfully installed but the JDBC connection keeps on failling.
I have 2 databases and 2 users.
However I have tested the ODBC Connection/DSN connection from my PC and it is working absolutely fine.
URL :  jdbc:jtds:sqlserver://192.168.11.161:1433/demo
Please refer the enclosed screen shots for failed JDBC and passed ODBC connection.
Please advice for the workaround!
Many Thanks!
Manish
Try adding the following to your to your JDBC URL
jdbc:jtds:sqlserver://192.168.11.161:1433/demo;domainname=
This is what I have in mine and it works
Thanks for your reply.
I do not have domain in my setup.
Please advice workaround, thanks!
Manish
Try replacing the with the name of the Server.
Hi ,
The issue resolved.
Every setps was right, but apparantly the server were connected trhough Wireless and some how there were some port blocking in that.
Tried on Switch, worked absolutely fine.
Thanks all, for the replies!
Manish Gupta
How install JDBC software on server, where SQL located???
873
