CRS Administration an CRS Engine Process are always going to Disable
Hi Everebody
I am installing the Unified CCX - but I am CRS
DISABLE mode. I put it back to enable an restar CIsci CRS Node Manger Servive  , but after 3 or 4 min its gos to disbale again
Does any body now how can I fix this issue
Other question concerning the "
CRS Admin Utily" - What is the user name and password ?
Re: CRS Administration an CRS Engine Process are always going to
Was IP address of the server changed after the UCCX was installed ?
In regards to the CRS admin utility  login question - the credentials you use is the administrator account (Administrator).
This is the account you used for installation and generally when you login into the box
Hope this helps
Anuj
Thanks for your feed back
Was IP address of the server changed after the UCCX was installed ? -  No its the same
This is the account you used for installation and generally when you login into the box - I am using the same credenciat but are not loggin , I receive a message "Administrator logon failed.Please ensure proper passwor is entered
Hope this helps
Anuj
I guess MIVR trace analysis and peek to the server will be required to better understand the issue , you know were I am going with this
Anuj
Please take a look some MIVR log
Hi Team .
Any help ?
As advised earlier in this regard I will suggest you to open a TAC case
Anuj
388
