04-24-2006 05:38 AM - edited 03-13-2019 11:42 PM
Is it possible to have the 2 script editors on the same PC? When 3.5 is already installed and I attempt to install 4.0 it detects the previous installation.
Chris
04-24-2006 07:44 AM
As far as I know, before 4.0, it always overwrote the older versions because everything is saved to the wfavvid folder. That is the reason and there is all the java stuff under that.
Is it giving you any option for installing under a different folder?
04-24-2006 10:25 PM
Try installing the CRS 4.0 Editor into a different directory at install time.
