CRS Script Editor 3.5 and 4.0 on same PC
Chris Deren
Is it possible to have the 2 script editors on the same PC? When 3.5 is already installed and I attempt to install 4.0 it detects the previous installation.
Chris
As far as I know, before 4.0, it always overwrote the older versions because everything is saved to the wfavvid folder. That is the reason and there is all the java stuff under that.
Is it giving you any option for installing under a different folder?
Try installing the CRS 4.0 Editor into a different directory at install time.
