Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CRSJavaService - COM+ (running low on available mem)
I have a problem at a customers installation. This installation is aprox. 3 months in usage and a service called "CRSJavaService" takes about 480000k memory. In the event logs the COM+ says that the system is running low on available memory.
The system is a cisco Callmanager 4.1(3) SR3a. With co-res installation of IPCX 4.0(2).
Is it correct that the server "CRSJavaService" takes that much memory?
Thanks for your help
Best Regards
Torsten
Silver
Re: CRSJavaService - COM+ (running low on available mem)
Yes, CRSJavaService does take up lot of memory.
Hi carenas123,
thanks for your answer. I restarted the server and now the service CRSJavaService.exe is at aprox. 350 MB virtual mem.
With high memory usage (500MB RAM & 1,5 GB virtual mem) the system has no problems but I thought that this couldn?t be a "normal" behavior.
Thank?s for your support
Greetings
Torsten
121
