CVP ASR Failover Issue
I have a 7.0(2) CVP implementation integrated with Nuance ASR.  I have both a primary and backup ASR server.  I have a IP Host reference in the VXML GW for both the primary and backup ASR servers.  The ASR features work correctly if I point the asr-en-us IP Host reference to either the primary or the backup server.  If I disable the services on the primary ASR server, no requests are sent to the backup ASR server.  Has anyone successfully configured a backup ASR server for CVP?
1 ACCEPTED SOLUTION
Green
Re: CVP ASR Failover Issue
Are you calling ASR from a CVP VXML application  (built with Studio) or from CVP microapps?
The "-backup" specification in the IP host table as described in the CVP Config Guide will work for a microapp, but from a CVP VXML application, you would need to use a VIP (virtual IP) supported by a CSS (Content Services Switch). Normally you want a two-pack CSS for fault-tolerance.
Geoff
Green
Geoff
I'm calling it from a CVP Studio application.  That makes sense why it would not work in that scenario.  Thanks.
384
