Contact Center
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 162 Views
  • 3 replies
Greetings, Can you provide the URL and Body example to update a campaign via the Outbound API.  I am able to Create Campaign, Get Campaign Definition, Get Campaign Records, Import Campaign Records, Delete Campaign Records, and Delete Campaign, but th...
galguire by Level 4
  • 1000 Views
  • 5 replies
A customer reports that contact center agents sometimes get a 403 Forbidden when trying to log into the desktop. This error resolves itself on its own after around a few hours; without going deep into troubleshooting, can someone give me a few hints ...
pescla by Spotlight
  • 87 Views
  • 2 replies
Moving away from VXMLGW to VVB and I am curious about having multiple entries in the VVB host-to-ip configuration.   Today I have something like thismediaserver Datacenter1_ip1, Datacenter1_ip2mediaserver-backup Datacenter 2_ip1, Datacenter2_ip2 The ...
