05-13-2016 09:24 AM - last edited on 03-25-2019 07:30 PM by ciscomoderator
Hi all,
We have an UCCE 11 with CVP deployment using Nuance as ASR/TTS. We have a testing purposes script that is able to "read" TTS without problems (for example with M microapp, providing inline_tts var).
The problem is that if ASR is enabled in the script (by changing input_type var from "D" to "B") TTS stops working (or at least is is not heard).
ASR seems to be working ok. I do not see any error in CVP or Nuance logs.
Any ideas?
Thanks and regards
05-16-2016 03:12 AM
Try defining inline grammar with user.microapp.grammar_choices , and see if it helps.
05-16-2016 05:44 AM
Hi Thanks for your answer.
How should it be done? user.microapp.grammar_choices=digits?
Thanks and regards
05-16-2016 06:55 AM
user.microapp.grammar_choices= "Sales/ Customer Service/ Help Desk"
05-17-2016 09:41 AM
But it didn´t fix the issue. Any other idea?
05-18-2016 03:25 AM
can you attach CVP logs covering the issue, i may try to look whats happening.
05-18-2016 04:27 AM
06-22-2017 06:52 AM
Did you ever find the solution to this problem?
