04-30-2009 09:22 AM - edited 03-14-2019 04:02 AM
Hello, Can someone assist me with this problem? Some agent I can monitor other agents receive the following error message. Is it a NIC issue if so which NIC do you recommend.
04-30-2009 09:50 AM
04-30-2009 09:55 AM
I have these to documents. However I'm not sure which card will work. Or if any have been tested. Our network team swears old the nic we have are the same. They come with the Dell computer.
04-30-2009 09:51 AM
There are multiple links on Cisco.com that talk about how to make sure your NIC will work. There are multiple links here: http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a00802576e1.shtml
Also, the CTIOS sys manager guide has a great section on this.
Finally, if all NICs are the same ensure your phone configuration is the same, also check the network configuration for each port.
david
