do_not_call not working
i have the following problem with do_not_call
1. numbers in do not call text file are still dialed
2. when i'm importing using configuration manager .. seems the file is not translated to a table (no Do_Not_Call table on sql server)
3. i'v read the Cisco Outbound Option: Do-Not-Call List Table documentation. There are more fields in the Do_Not_Call table .. i'v only 2 (not editable).
how can i activate do_not_call? do_not_call table should be on the dialer db right? the same db as were the campaings are loaded..
Thanks in advanced!
Re: do_not_call not working
is it true that do_not_call is no longer stored in a table .. but in the memory?
i'v checked the manual.. do_not_call is now stored in the memory .. the list is imported and the .restore file is created .. but those numbers in the list are stille dialed.
i'v tried many formats in the file
11111111
011111111
11111111,0
011111111,0
Thanks for your help
what is extension .. is that always filled?
137
