Finesse silent monitoring vs CUCM whisper coaching
Hi all,
My understanding is both of these function uses the same resources from CUCM which is the BIB. And the only way to do whisper coaching is through CUCM. So for all the supervisory function (silent monitor, barge, intercept), they will be able to use Finesse Supervisor but when they want to do whisper coaching they will need to use the IP Phone directly by doing silent monitoring first then do whisper coaching. Is that the correct flow?
If setup in such a way, will there be any conflict between Finesse & CUCM?
Thanks!
-JT-
JT,I'm not sure I completely
JT,
I'm not sure I completely understand your question. Finesse monitoring comes through the phone, same was as whisper coaching would and yes they are both through the BiB.
david
You can check out the 3rd
Parsec’s MARS Silent Monitor & Coaching application for Cisco Unified Communications Manager allows a supervisor to silently monitor & whisper/coach to a monitored agent during a conversation between an agent and a customer without the customer or agent knowing that he/she is being monitored.
The application does not require Cisco UCCX for enabling the monitoring feature in CUCM.
Check the discussion : https://supportforums.cisco.com/document/12296686/silent-monitoring-coachwhisper-cisco-call-manager-without-need-uccx
927
