Gila Wallboard Overall stats not correct
I am having an issue where the Overal Stats don't reflect the queue stats for abandoned calls.  The abanonded calls appears to only reflect the data from one of our CSQ's.  I have ran the sql queries and the information that is displayed is correct in the tables.
I am using
SELECT * FROM RtICDStatistics
to get the abandoned calls.  When I run
SELECT CSQName, loggedInAgents, availableAgents, callsWaiting, callsHandled, totalCalls, callsAbandoned, convLongestWaitDuration, endDateTime FROM RtCSQsSummary ORDER BY CSQName I see abandoned calls in both CSQ's.  It appears as if the total from the last one is what I am getting for the overall stats.
Joe
1 REPLY
Joe,
Maybe it is time to switch to 2Ring DASHBOARDS & WALLBOARDS - www.2Ring.com/DW, there is a free trial that you can have up and running in 5 minutes or less.
Michal, 2Ring
528
