Help in UCCE Outbound System
Hello, my name is Eric and i have a little problem. First i create a UCCE 7.5 environment and i try to started a outbound system, and i do everything that the outbound guide showed me, but the outbound system didnt works. I need some help because the outbound configuration is perfect, but the campaign doesnt start. I want to shows you a log about the dialer.
locate port: 008, owner: RESERVE_PREDICTIVE
13:10:05 dialer-baDialer Trace: (CPORT) SetState, port: 008, state: GET_AGENT
13:10:05 dialer-baDialer Trace: MRTask::ProcessNewTaskFailureEvent: Received NACK for NEW_TASK
DialogueID=271, SendSeqNo=1, ReasonCode=Unknown routing problem
DialogueID=272, SendSeqNo=1, ReasonCode=Unknown routing problem
DialogueID=273, SendSeqNo=1, ReasonCode=Unknown routing problem
13:10:05 dialer-baDialer Trace: (PDR) MR Reservation Failed for port: 006, state: GET_AGENT, reason: 209
13:10:05 dialer-baDialer Trace: (PDR) End port: 006
13:10:05 dialer-baDialer Trace: (PM)
Release port: 006, state: [GET_AGENT]
13:10:05 dialer-baDialer Trace: (CPORT) SetState, port: 006, m_ReservationCallTime: 0, state: IDLE
13:10:05 dialer-baDialer Trace: (PDR) MR Reservation Failed for port: 007, state: GET_AGENT, reason: 209
13:10:05 dialer-baDialer Trace: (PDR) End port: 007
Release port: 007, state: [GET_AGENT]
13:10:05 dialer-baDialer Trace: (CPORT) SetState, port: 007, m_ReservationCallTime: 0, state: IDLE
13:10:05 dialer-baDialer Trace: (PDR) MR Reservation Failed for port: 008, state: GET_AGENT, reason: 209
13:10:05 dialer-baDialer Trace: (PDR) End port: 008
Release port: 008, state: [GET_AGENT]
13:10:05 dialer-baDialer Trace: (CPORT) SetState, port: 008, m_ReservationCallTime: 0, state: IDLE
13:10:06 dialer-baDialer Trace: (CM) Request records from campaign manager, skill: 5004, records: 100
13:10:06 dialer-baDialer Trace: (CB) Requesting callback records
13:10:06 dialer-baDialer Trace: (CM) Received customer records, count: 0, skill: 5004
13:10:06 dialer-baDialer Trace: (CM) Received callback customer records, count: 0
Thanks.
Green
Re: Help in UCCE Outbound System
If you recall the way this works, the 30VIP phones created by the Dialer install are used for two things. 1 - to place a reservation call to the agent, and 2- to call the customer. When the Dialer detects that the customer has answered it transfers the near end from the Dialer port to the agent's phone, which is configured with call waiting, then drops the reservation call from underneath.
It looks from your trace that the reservation call is failing. Are the device pools compatible?
You can test by using the dialogictest.exe program to choose a dialer port and call the agent's extension. Although the commands from this app are SCCP and the Dialer controls these ports through JTAPI, you should still be able to place the call. Make sure you stop the Dialer while using dialogictest as these two programs cannot coexist.
I know there was a change in the later version of the product where the reservation call was changed from being a real call to a fake call - I don't know where your version fits in this timeline.
Give it a shot anyway.
Geoff
I am facing the same issue. are you able to resolve this?
The IVR campaign is working fine and the Dialogic Test is also workin!! but the agent based campaign is not dialing the customer, neither can i see the agent getting reserved.
Here is the log:
Allocate port: 003, owner: RESERVE_PREDICTIVE
10:32:42 Trace: (CPORT) SetState, port: 003, state: GET_AGENT
10:32:42 Trace: MRTask::ProcessNewTaskFailureEvent: Received NACK for NEW_TASK
        DialogueID=23, SendSeqNo=1, ReasonCode=Unknown routing problem
10:32:42 Trace: (PDR)   MR Reservation Failed for port: 003, state: GET_AGENT, reason: 209
10:32:42 Trace: (PDR)   End port: 003
10:32:42 Trace: (PM)
Release port: 003, state: [GET_AGENT]
10:32:42 Trace: (CPORT) SetState, port: 003, m_ReservationCallTime: 63, state: IDLE
10:32:43 Trace: (CM)    Request records from campaign manager, skill: 5012, records: 100
10:32:43 Trace: (CM)    Received customer records, count: 0, skill: 5012
10:32:44 Trace: (SGM)   Request skill stats, SG: 2, periph: 5000
10:32:44 Trace: (SGM)   Request skill stats, SG: 4, periph: 5000
10:32:44 Trace: (SGM)   Request skill stats, SG: 5, periph: 5000
10:32:44 Trace: (CM)    Request records from campaign manager, skill: 5012, records: 100
10:32:44 Trace: (CM)    Received customer records, count: 0, skill: 5012
10:32:44 Trace: (SGM)   Skill group stats received, SG: 2, agents - logged in: 5, available: 5
10:32:44 Trace: (SGM)   Skill group stats received, SG: 4, agents - logged in: 1, available: 1
10:32:44 Trace: (SGM)   Skill group stats received, SG: 5, agents - logged in: 1, available: 1
10:32:44 Trace: (SGM)   Skill group balance, SG: 5 Agents - logged in: 1, percentage: 100, available: 1, resrving: 0, cumulative ports needed: 2.50
10:32:44 Trace: (SGM)   Skill group balance, SG: 5, Port Percentage: 100.000000, Ports: 5 --> Ports Allocated: 5
10:32:44 Trace: (SGM)   Predictive reserve request, SG: 5, count: 1
10:32:44 Trace: (PDR)   Predictive dial request, SG: 5, count: 2
10:32:44 Trace: (PM)
Sandeep
Sandeep, have you checked to
Sandeep,
have you checked to make sure that under you Agent Targeting rule, you have a new rule setup with your CUCM Peripheral and the routing client as your Dialer PIM and added the agent extensions there ?  assuming your Dialer is a SIP dialer (not SCCP), have you made sure you have a SIP trunk configured on CUCM to the Dialer ?
Check the following things in your configuration,It might be helpful to you to resolve those kind of issues.
1>Check the Dial Number configured in Campaign is same as the MR_PG  Routing client Dail number.
2>Check the Dailer ports and Agent Extensions are mapped in same CUCM and associated with same dial Number.
Nalini.g
Nalini's first suggestion goes in the right direction, go through these items :
  1. What are the Skill Group and Dialed Number configured on your Campaign ?
  2. Open the Dialed Number List tool, does the DN on the Campaign exist here for the Media Routing PG's Routing Client ? Is the DN mapped to Call Type and a Script ?
  3. If yes, monitor the script from Script Editor, you should see route requests coming in.
  4. Verify that the Script has a Skill Group node and the Skill Group is the same as the one you configured on the Campaign ?
  5. Once an agent is chosen by the Router we need to return a label, do your agent's Device Targets or Agent Targeting Rules have labels configured for the Dialed' MR PIM Routing Client ?
If you go through these steps, it should work
Cheers,
Kris
I have similiar issue. Fixed
I have similiar issue. Fixed by step 5.
Thanks.
Had same messages in EMSMON debug.
VRU was not configured(set to NONE) in MR PG.
You can acsess it ConfigManager > PG Explorer > VRU tab.
This issue revealed via rtrlog.exe tool
Oleh, thanks a ton!That VRU
Oleh, thanks a ton!
That VRU missing was my problem.
Well done.
-- best regards, Igor
1957
