01-28-2012 12:03 AM - edited 03-14-2019 09:15 AM
Hi all,
We are facing High uccx engine memory usage ,our system version uccx 8.2 su4,when ever this problem hapening we are facing all agent desktop failure also.Any one facing this same issue.Kindly attached RTMT screen shot.
Thanks.
01-28-2012 03:27 AM
I saw a similar issue after upgrading to 8.0(2) SU3. We found that this was because a few desktops did not automatically update ... for various reasons. Ensure that all desktops are on the correct version, which should be 8.0.2.500 for SU4.
Brian
01-28-2012 09:02 PM
Thanks your update,I will check all agent desktop and i will update you. after agent desktop upgradation still you are facing this issue or resolved please update me.
01-29-2012 12:37 AM
Hi Brian,
Yes you are correct ,We found that four agent desktop are not updated the newer version.Now all the agent desktops are
8.0.2.500.
01-29-2012 01:34 AM
Yes, our issue was resolved after upgrading desktops.
Please rate helpful posts.
01-29-2012 10:43 PM
Hi ,
We are monitering .....
Thanks.
01-30-2012 11:33 PM
Hi ,
Still we are facing high uccx memory usage but this time didn't face cad failure please find RTMT screen shot.
Thanks.
02-03-2012 09:14 AM
Hi All,
Any one facing this issue..
02-03-2012 10:00 AM
Hi Renji,
This is a known defect CSCtn87921 and its caused by a memory leak in BIPPA service
-Please follow the workaround of restarting the BIPPA service from serviceability section on both servers if present
-Check if the alert disappears
-It should have been fixed in SU4 but apparently not
Keep me posted
Prashanth
