Community Member
Holiday Chek script won't work
I've downloaded holiday check script form some topic here. It worked for that guy, so I guess it should work again. I also have created dates.xml like he did, and have uploaded it to "c:\Program Files\wfavvid" (that's what he did) and to "documet repository/en_US" (just in case), but, when I call my CCX number, it reports system error.
I have called that script using subflow in my script, and I have mapped appropriate variables. Validation is passed for both scripts.
Does anyone know what I have left and how to make this work?
            Svetomir
1 REPLY
Super Bronze
You need to look at the MIVR logs or debug the script.
You can probably just run the subflow from the editor, setting a breakpoint on the first step and then stepping through it (editing the vars to emulated the parameters you push in when you call it from a proper script).
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
245
