Holiday Script variable problem
I'm installing an holiday script on a UCCX 9.0.2 Premium.
Here's my problem:
on my script i have
XMLDocument = Create XML Document (XMLDocument)
the variable is:     NAME:XMLDocument     TYPE:Document          VALUE: DOC[holidays.xml] @ [en_GB]
Everytime i run a debug the value of the variable above turns to null, giving on next step the error: "Source document variable "XMLDocument" has null value."
I´m on ccx editor 902
Thanks.
  • Contact Center
1 ACCEPTED SOLUTION
Depending on the version of UCCX 9.0.2 (base) you are probably running into a bug that I found and then was acknowledged by this post: https://supportforums.cisco.com/message/3930553#3930553
Unfortunately if you are..and my hunch is that you are..you'll need to debug in Reactive Mode.
use the Set step to assign the value of the variable.
Also, I am not sure about the syntax. Try Set XMLDocument = DOC[holidays.xml] @ L[en_GB]
G.
Hi Szabo,
Thank you for your response.
I've already tried and the Set XMLDocument does not alter anything the value after i start the script remains null.
Paulo Pereira
Hi Paulo, can you please make sure the holidays.xml file is in the correct directory in the Document Repository?
G.
Thank you very much, i've passed 2 day´s working around this.
Thank you to all the people in this Forum.
Cheers.
Paulo Pereira
156
