how forwarding calls between IP Phones
i have 2 IP Phones 7910 and 7912 which use the same direct line (exp: 021657689 )for calling and receiving calls but with different extension :
7910 --> extension= 796
7912 --> extension= 667
i want to configure receiving calls in first time in cisco 7910, and after 3 rings the call will be forwarded to cisco 7912, don`t forget that they are using the same direct line
where i must exactly configure this option in Phone Configuration page ?? or directory Number Configuration page ??
Any help will be appreciated
zahida
1 REPLY
Hall of Fame Super Silver
Re: how forwarding calls between IP Phones
You want to setup call farward No answer on the Device line, under 796 forward to 667. You did not specify which version of CCM you are running, with 4+ you can change the Ring No Answer time for that line on the same page, for earlier version there is a service paramater which applies globally.
Chris
83
