Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How to enable HDS in System IPCC
I am trying to set up a System IPCC 7.0 environment, everthing is fine except HDS, which by default is not installed by ICM setup, so I created it by 'icmdba', however I can't find any place to enable it in ICM. (In traditional ICM, re-run ICM set up to check the option). So there is no "distributor replication" service so far. Where can I turn on HDS?
Wei
MTS Allstream
Re: How to enable HDS in System IPCC
HDS is called Administration and Reporting Server in System IPCC.
You upload the software onto each server in the required model and then carry out config via the web tool https://
Address>/ipccAdmin
I don't recall using icmdba for the install at all (I think it runs in the background)
I got answer already, all-in-one deployment model doesn't have HDS, instead, it use central DB for historical reporting.
Thanks.
Wei
301
