ICM and Avaya connectivity question
Is it possible to connect the PGs with the AES using WAN? Which are the requisites?
Carlos
Re: ICM and Avaya connectivity question
Carlos,
Yes PG's do talk to AES via CVLAN. PG's can even get info from Avaya CMS.
Your Avaya team should be able to help you on AES configuration.
Make sure you check the versions and rev's for both AES and PG's.
Good luck,
Baseer.
Hi Basser,
I would like to know the maximun latency and the minimun bandwidth requiered by using a WAN connection between AES and PGs.
Thanks.
Carlos
134
