Community Member
ICM VRU Problem
I have installed the ICM 7.0. But I am getting following error in VRU as shown in the screen shot.
I am also not able to open the third party software sybase central.
Please see the attachement for errors and let me know how to solve this issue.
Re: ICM VRU Problem
I think you have done any wrong while configuring VRU PG at ICM Configuration Manager. Recheck it, if problem still persists then please attach the screenshots of the 'Peripheral', 'Advance' and 'Routing Client' tab of VRU PG explorer as well.
Community Member
Re: ICM VRU Problem
Thanks for the reply, I have attached the VRUP PG configuration screen shots.
I have made two Network VRU. Also see the attachement
Community Member
Re: ICM VRU Problem
Have you enabled the PIM in the Peripheral Gateway setup on the PG? Using correct IP adress and port? Do you have any Firewall between the servers? Have you checked so you have enabled the actual service on the IVR and is using port 5000?
You enables the IVR under Subsystem - ICM by choosing Yes on Service Control radio buttons.
