ICMDBA Manual Synchronization between Logger A DB to Logger B DB
Hi all,
How to perform Manual Data Synchronization not the configuration synchronization from Side A Logger to side B Logger.
I Searched in the Web, and found the configuration Sync for the Loggers.
If anyone found this doc, send it to me or is there any manual steps to be followed to synchronized
Kumar.V
Blue
Re: ICMDBA Manual Synchronization between Logger A DB to Logger
I don't follow your question exactly. Are you saying you DO NOT want to use ICMDBA to sync your databases? If so, why not?
I need to replicate the Databases from Logger A to Logger B.
I need to know how should we do it.Its not that I should not use ICMDBA.
Even I tried using ICMDBA to synchronize the DB, but its for the Configuration sync between the SideA and SideB Logger DB's.
Kumar.V
ICMDBA will do this for you, just select historical rather than configuration records. Export it into a file, copy the file over and then import into the other side.
Why would you need to sync the history though? The Logger's Recovery process will note a difference in data between the two loggers and will sync the nissing records automatically.
/Jeff
980
