Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VIP Purple
Incoming Calls
Hi All,
I need to increase the number of rings on Agents phone before it gets transferred to next available agent.
Currently, after 3 rings call gets transferred to next agent.Is it possible to do so?
regds,
aman
Re: Incoming Calls
Hello Aman,
Yes, this is possible. You need to change the 'Ring no answer time' parameter in the desksettings for those agents.
Agents need to login again to receive the new settings.
--basv
VIP Purple
Re: Incoming Calls
Hi Basv,
Do we need to change this setting in CAD?
Is these any other way since we do not have CAD installed on Agents desktop?
regds,
aman
Re: Incoming Calls
Aman,
What CC solution are you using exactly?
--basv
VIP Purple
Re: Incoming Calls
We are using CRS Standard 5.0(2)_Build064
aman
Re: Incoming Calls
In that case, IIRC, you need to adjust the timeout parameter when you select the agent for the call. I'm more used to UCCE nowadays, maybe someone else can confirm this.
Re: Incoming Calls
That is correct. In your script, on the "Select Resource" step, you will need to adjust the Timeout parameter. It currently defaults to 10 seconds which is approximately 3 rings.
Re: Incoming Calls
Take a care, if your agent's phone have a call forward (voice mail or someting else) this timeout must be smaller than the time out for busy or non answer on your CUCM
regards
Farid
157
