Ingress and VXML Gateway Split up
Presently I have a Colocated Ingress and VXML gateway for my setup. I am planning to split up the Ingress and VXML functionalities as I have to increase the call Queues in my CVP Comprehensive setup, as the present hardware does not support more number of Queue calls. Please let me know whether the points mentioned below will work with the upgraded system
1. Configure bootstrap dial peers and applications to the new VXML gateway and remove from the existing Colocated gateway
2. Configure ringtone and sip error tone dial peers in the new gateway
3. Point static SIP Static routes of ringtone, error tone and label from ICM from CVP to VXML Gateway
At present we have only one colocated Ingress and VXML Gateway and we have also planned for one ingress and one VXML Gateway for the split up
Dass
Everyone's tags (5)
1 ACCEPTED SOLUTION
Green
Re: Ingress and VXML Gateway Split up
You are on the right track.
Let's just forget about what's on the current gateway (a combined gateway where we could remove stuff later) and introduce the VXML-only gateway.
1. You probably have "Send To Originator" configured on several patterns - 8111> (the VRU transfer label), 91919191 (ringtone) and 92929292 (error). Remove these patterns.
2. Add these patterns as static routes that point to your new VXML gateway - now the call won't go back to the ingress gwy
3. Install in the flash: bootstrap TCL and VXML, ringtone and error TCL, ringback and error WAVs.
4. Configure the HTTP client cache and the IVR prompt app
5. Configure the voice service voip section
6. Configure the apps - new-call, handoff, cvperror, ringtone.
7. Create the bootstrap, ringtone and error dial peers.
Regars,
Geoff
Green
Regars,
Geoff
Thank you Geoff for the update!!!!
Dass
530
