Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Injecting DTMF events from external system
I want to send dtmf events to cisco cvp, these events will be pushed to the platform from another channel (tcp or http or webservice...)
The target is: to send dtmf events on behalf of the caller
Scenairo:
CallerA: calls the IVR and does not press anything
Another software system: sends message to the IVR with content similar to: "calledID=xxxx&pressedKey=1"
IVR: acts as if callerA pressed 1 and changes the prompt being played
I tried to find this feature in the following pdfs, but didnt find it yet
# Element Specifications for Cisco Unified CVP VXML Server and Cisco Unified CallStudio.pdf
# Programming Guide for Cisco Unified CVP VXML Server and Cisco Unified CallStudio.pdf
please advise, thank you
Khaled
Everyone's tags (3)
Silver
I think you'll have a better chance of getting your question answered in the developer forums.
http://cdn.cisco.com/web/cvp/forums/-/message_boards/category/1056972
I don't understand what you're trying to do.  You could write your VXML application to go a specific path if there is no user input, what is the specific need of DTMF inside CVP?
Actually, reading this a bit more, what is the communication channel between CVP and "another software system"?  Web service, DB?
david
140
