Integer to String conversion
conoufri
Is there a way to convert an Integer Parameter to a String and save it into a String Parameter, in IPCC Express 3.5?
Christos
2 Accepted Solutions
Chris Deren
You can accomplish this by executing the Java method, use Execute Jave Method step, I don't remember exactly which method to use, but there should be one pre-defined.
Chris
swright
I have been using this script successfully as a subflow called from my main script. If you want to keep the original integer value, create a temp integer value and use that instead, Use the Set step to set the temp variable's value to the original integer value.
Chris Deren
Chris
Thx a lot for your help.
C.
swright
Thx a lot for the info and file.
C.
