IPCC 3.x monitoring and recording problem
When I use Desktop Administrator and click on the VoIP Monitor under Enterprise Data Configuration I get a error message: The program failed to connect to the ODBC client on the PC. I checked SYNC_SERVER_A ODBC in System DSN connections and they looked good.
I also verify the password under the registry key: HKLM\SOFTWARE\ODBC\ODBC.INI\SYNC_SERVER_A
for the password under SPLKPWD match with encoded string pwcrytp.exe. The password to "sa" did not change, as works without problems Synchronize Directory Services in Cisco Desktop Administrator.
1 REPLY
Bronze
Re: IPCC 3.x monitoring and recording problem
Troubleshooting IPCC Agent Login Failures : CF_Invalid_AgentID_Specified :
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a0080094b11.shtml
Why is the Bridge CTI Application Unable to Pass Call Data to the Agent's Desktop? :
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a00800948e1.shtml
115
