IPCC ColdStandby MCS-7845-I Drive Swapping
I need the procedure for Removing a drive from one IBM MCS-7845 Server to another for the purpose of createing a Cold Standby Server for an IPCC Install. On a HP MCS all you have to do is take a drive from the primary move it to the secondary and boot the server. Press F2 to fail the non-responding drives and the server boots up. On the IBM server the process isn't so simple. If I move a drive on the IBM Primary to a secondary (same slots) I get options to Retry, Defunct or Ignore. If I Defunct, then I loose the drive and the controller won't try to boot from it. I can also hit CTRL-I and try to import the RAID config from the Drive, but it Defuncts the drives and won't let me boot from it. Anyone know the procedure to get this done?
194
