Community Member
IPCC CTI Route point gets busy signal
After completing the script wizard I created a Route point with an extension of 5080, this was not used anywhere in the CCM box before. I get a busy signal when I dial it from any phone. It doesn't seem to get handed off to IPCC at all.
What are good places to check or potential problems?
Running IPCC 5.0 and CCM 6.1.
Re: IPCC CTI Route point gets busy signal
HI there,
if this is failing already internally I would check for the JTAPI SubSystem to be in service, for the JTAPI Trigger to be properly configured and eventually for the route point to be registered with the Call Manager and confrim the JTAPI plugin was installed on the UCCX.
If then it will fail for an external call, but work for the internal check on the CSS of the CTI Route Points to include the GW Partition.
Hope this helps,
Riccardo
PS. Please rate useful posts accordingly.
Community Member
Calling party (internal phone and pstn gw) should have CTI Ports partition in CSS
Wayne.W
655
