Community Member
IPCC Express 4.0(4) Upgrade to SR1 Problems
Hi.
I'm trying to upgrade CRS 4.0(4) to CRS4.0(4)SR01. I open BARS on the BARS server (CCM Publisher) and I selected the restore wizard and select the correct SR01 and also one of the servers. After a while it says to go to each server on the cluster (4 servers on mine) and run CRS Update Utility from there.
Running the CRS Update Utility and selecting the SR01 patch it says "The Update Utility is unable to copy the contents of the patch". I'm having the same error on all servers and I'm unable to finish the upgrade process.
Any ideas?
Thanks in advanced,
-Jose
Silver
Re: IPCC Express 4.0(4) Upgrade to SR1 Problems
You are running into a bug here. The bug deails:
CSCsb17809 - Update Utility is unable to copy the Contents of the Patch
Workaround: Copy the patch archives to a path which has no spaces, Eg: (C:\PatchArchives) and then run the Update Tool.
Community Member
Make sure that the file path does not contain any space. I tried it and it worked for me.
Community Member
Ok. I got it working. I was having the .tar file on the desktop and it wasn't working. I moved the file on a folder under C: drive and it works . Probably something related to permissions I think..
Thanks to all.
-Jose
Community Member
No it is not due to permissions, this is exactly what was explained by other fellow "bug". Since your desktop folder is under few other folders and they have a space in their name and that is why you were unable.
Thanks, Ovais.
Community Member
Exact ! the Desktop folder is under the 'Documents and Settings' folder which contains space.
219
