IPCC help
Dears,
I have ICM 7.2.7 and CTIOS with the same version
I need the agent state to change from ready to not ready after 3 abandoned rings
Mohamed
Green
Re: IPCC help
Commonly called RONA (Redirect on No Answer, or Reroute on No Answer).
IP IVR or CVP? - the mechanism is different.
See IPCC Installation and Configuration Guide for Cisco IPCC Enterprise Edition Release 7.0(0) section 6-6 and 6-7.
Geoff
Re: IPCC help
Hi Geoff,
This is based on CVP
Mohamed
Green
Re: IPCC help
Also described in your CVP Guide. As you probably know after reading the previous reference ;-), CVP does this with ROuter Requery and it's a little involved - there are three timers you must sequnce correctly.
"Configuration and Administration Guide for Cisco Unified Customer Voice Portal Release 7.0(2)" - page 420.
Geoff
143
