IPCC Monitoring and recording supported codec
I have a IPCC server with codec g729 due to some remote gateways connected to it. Can I configure the monitoring feature with this codec?
Hall of Fame Super Red
Re: IPCC Monitoring and recording supported codec
Hi Jose,
According to the Best Practices documentation g729 is supported.Check page 23 Section 5.1.5 Voice Encoding Protocols. From this good doc;
http://www.cisco.com/application/pdf/en/us/guest/products/ps427/c1225/ccmigration_09186a008038a4bb.pdf
Hope this helps!
Rob
Hi Rob,
I wanted to know if someone has actually used this codec for the monitoring feature because I saw this document you referring to, but I also found this other one below, look at page 52, where it says that g711 must be used, so I don?t know now.
Thanks and regards,
Jose
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_0/english/administ/crs401ig.pdf
Hi Jose,
I was made in this year an implementation using monitoring (spam) with G729. It's works!
Hope This Helps
Fabio
Thanks for you input, Fabio, I?ll go ahead and try it.
Jose
142
