Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IPCC X 4.1 - remote monitor Calls (Wideband Codec) ?
We are running IPCC 4.1sr1 . We can successfully monitor calls/ Record calls and Remote monitor G711 calls. However when we attempt to do this for Wideband calls (Wideband is used throughout CM 4.3 cluster)that are servicing the internal customers on IPCCX we just get silence.
Is the Wideband codec supported on IPCCX 4.1?
Thanks in advance Mark.
1 REPLY
Silver
Re: IPCC X 4.1 - remote monitor Calls (Wideband Codec) ?
Try bug - CSCsk98030
143
