ipccx call routing not working
I have UCM 6.1(2) and IPCCX 5 using IP Phone Agent.
My AA route point works fine and can route to an entered number phone
My agent can log on to IPPA fine and screen says ready
When I dial the ICD route point I get the announcement that all agents are busy and then the system sets my ready agent to not ready.
Debug shows that IPCC selects the correct agent, but then it sets the agent to Not ready, as though it has tried to deliver the call and there is no answer.
Any ideas would be most welcome, thanks.
Hall of Fame Super Silver
Re: ipccx call routing not working
The issue is most likely Calling Search Space/Parition configuration on CallManager. Ensure that the CSS applied to the cti ports has access to the agent's ACD line parition.
HTH,
Chris
Hi, Thanks for the response.
That was exactly the problem.
Glad it worked for you, please rate all useful posts!
Chris
104
